8 years agokernel driver mismatch after switching from SDK 16.1 to 17.1
We have recently switched from SDK16.1 to 17.1 The aocl diagnose works fine. The aoc -list-boards shows the boards as expected. The aoc full compile works. The make works for the host pro...
8 years agoYou should install the new kernel driver using "aocl install" AND reconfigure your FPGA via JTAG/PCI-E with an OpenCL image compiled with the new version and reboot your machine. It is basically like setting up the board again from scratch. You should also recompile your host code with the new BSP.
