8 years agojtag debugger dosen't finds the connected cyclon ll processor
Hi I am using cyclon ll processor and Nios2 13.0 IDE. I have started facing a problem that my USB blaster doesn't recognize the hardware. When i did jtagconfig -d 1) USB-Blaster [USB-0] Un...
8 years ago --- Quote Start --- Sorry for making confusion, I am using altera Cyclone 2 FPGA, which doesn't gets identified by Blaster cable. When ever I do "jtaconfig -n" I get, USB-Blaster [1-2] Unable to read device chain (JTAG chain broken). But when I apply power supply to the board, it boots up normally. At the same time blaster cable doesn't identify the board. --- Quote End --- The screenshot you posted doesn't match up with what you are saying. I guess that is the confusion here. Are you talking about executing code on the Nios in the IDE? This is a separate operation from programming the FPGA with the hardware design.
