8 years agojtag debugger dosen't finds the connected cyclon ll processor
Hi I am using cyclon ll processor and Nios2 13.0 IDE. I have started facing a problem that my USB blaster doesn't recognize the hardware. When i did jtagconfig -d 1) USB-Blaster [USB-0] Un...
8 years ago --- Quote Start --- But when I try to program controller I get error --- Quote End --- What sort of 'error'? Your description and screen shots all show everything working. I can't read green trace messages. However, green messages are good, red are bad. the '100% (successful)' indicates the FPGA has programmed successfully. Does your FPGA not do what you expect when it's programmed? Cheers, Alex
