Jack_Lin
5 years agoJam STAPL Player Quartus v16, v17
We have code that programs .jbc file to the FPGA using a controller.
Everything works fine when the .jbc is compiled with Quartus v16.1
But it fails when it's compiled with any newer Quartus vers...
- 5 years ago
I would recommend you to manually generate the jbc file as this will let you have the option to enable the ISP programming mode.
Jack_Lin
5 years agoYes.
The results were the same. v16 .jbc file, which works, is smaller than the v20 .jbc file. I tried converting using the Programmer, and also showed the same file size difference.
