Jack_Lin
5 years agoJam STAPL Player Quartus v16, v17
We have code that programs .jbc file to the FPGA using a controller.
Everything works fine when the .jbc is compiled with Quartus v16.1
But it fails when it's compiled with any newer Quartus vers...
- 5 years ago
I would recommend you to manually generate the jbc file as this will let you have the option to enable the ISP programming mode.
JohnT_Altera
5 years agoHi,
Have you try to manually create the JBC file using Quartus Programmer?
