Jack_Lin
5 years agoJam STAPL Player Quartus v16, v17
We have code that programs .jbc file to the FPGA using a controller.
Everything works fine when the .jbc is compiled with Quartus v16.1
But it fails when it's compiled with any newer Quartus vers...
- 5 years ago
I would recommend you to manually generate the jbc file as this will let you have the option to enable the ISP programming mode.
JohnT_Altera
5 years agoHi,
May I know how do you generate the jbc file? Have you tested the sof file to be working? May I know if the you are facing jbc programming failure or flash to fpga configuration failure?
- Jack_Lin5 years ago
I am generating the .jbc file automatically when doing compile by going:
Assignments -> Device -> Device and Pin Options -> Programming Files -> Check the Jam STAPL Byte Code 2.0 File.
I am not able to try the .sof file, because with our design, the only way to program is to use .jbc file.
If you look at the 2 zip files that I attached, you can see the error message (v16 works and v20 doesn't work).
