It produced no waveform output(xx) of the state machine using d flip-flop
- 5 years ago
Hi Jun,
I would suggest you to view you RTL netlist and see the logic if they are designed as intended and the logic and connections have been interpreted correctly by the software. You can use the RTL Viewer and State Machine Viewer to check your design visually before simulation. Tool --> Netlist Viewer --> RTL viewer/state machine viewer.
Analyzing Designs with Quartus II Netlist Viewers
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii51013.pdf
Hi Jun,
