12 years agoissues in running CycV_SoC with DDR3 RAM on Dev_Kit
Hello, I am in an internship and my task is to perform a DDR3-SDRAM memory test on the "Cyclone V SoC Development Kit" with the Cycone V SX 5SCXFC6.. FPGA. ( To see what the difficulties are ...
12 years agoHi Socrates,
I fixed the issue with help from the customer support :) Currently I am running some memory tests and will post my solution soon. First of all the preconfiguration of the Micron RAM is the problem for the pin_assignment warnings, cause the supply voltage is "1.5V DDR3" and some memory initialization options have to be changed. Furthermore one should copy the "Memory Timing" + "Board Settings" from a reference design of the corresponding Evaluation Kit. Next problem is with the reset sequence and a possible deadlock when you auto generate a reset network. ... there are some more points to be considered to fix the cirtical warnings concerning ddr timings, but I will show my results soon. Which board are you using? I hope this could help you a bit. Kind regards.
