JDlug
6 years agoIssue with Quartus Prime PRO for Stratix 10 when using a string type in a VHDL project.
Hello, When using "Quartus Prime Pro 20.1" software with "Stratix 10" chip, I have a problem with VHDL string type in my projects. At the same time, I don't have this problem when using "Quartus Pri...
KhaiChein_Y_Intel
6 years agoHi,
Do you have any updates?
KhaiY
JDlug
6 years agoSomething has cut the code, so here it is again:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_ARITH.all;
entity e1 is
port(
data : out std_logic_vector(3 downto 0);
clk : in std_logic
end e1;
architecture arch1 of e1 is
component e2 is
port(
clk : in std_logic;
str_1 : inout string(1 to 4);
vec_1 : inout std_logic_vector(31 downto 0)
end component;
shared variable str_1 : string(1 to 4);
shared variable vec_1 : std_logic_vector(31 downto 0);
shared variable s1, s2 : std_logic;
begin
instance_1 : e2 PORT MAP (
data => data,
clk => clk,
str_1 => str_1,
vec_1 => vec_1
process
begin
wait until clk'EVENT and clk='1';
s1 := not s2;
end process;
process
begin
if s2/=s1 then s2:=s1; str_1:="ABCD"; end if;
vec_1(7 downto 0):= conv_std_logic_vector(character'pos(str_1(1)),8);
end process;
end arch1;
library IEEE;
entity e2 is
port(
clk : in std_logic;
str_1: inout string(1 to 4);
vec_1: inout std_logic_vector(31 downto 0)
end e2 ;
architecture arch1 of e2 is
begin
process
variable clk2: std_logic;
begin
data<=vec_1(3 downto 0);
clk2:= not clk2;
end process;
end arch1;
(jd)
