13 years agoEdit1: In VHDL no object can have a dynamic size.
Edit2 and 3: This is what I tried yesterday before giving you the hint. It looks a bit like your code, and generates a big RTL diagram and use quite some LCsprocess( source , destination , msbd , lsb )
variable si : natural ;
begin
output <= (others => '0') ;
si := 0 ;
for i in 0 to 31 loop
if ( i < to_integer( unsigned( lsb )) ) then
output(i) <= destination(i) ;
elsif( i < (31 - to_integer( unsigned( msbd ))) ) then
output(i) <= source(si) ;
si := si + 1 ;
else
end if ;
end loop;
end process ; I didn't restrict si's range, but that doesn'y change anything, neither in the RTL-diagram, nor in the amount of LCs (edit) I didn't spot the '31 to 0' error, as Daixiwen did. Another way to do the same: It assumes you have a barrelshift component (look in Pedroni's Circuit Design with VHDL' page 187 ff.). The other operators are standard. Except the reverse function, which is is easy to write with a loop. The RTL diagram will be small and understandable, and it will use a lot less LCs.
