ISSP in Quartus
I am programing with .pof file and I have a active JTAG connection.
Using .pof file quartus shows flashing successful.
As flash can be done through programmer window as well as In systems and sources and probe editor.
from both places I am able to flash using .pof file.
but after flashing through In systems and sources and probe editor, its is showing "No instances found in the current project or on the device" .
If I am able to flash through USB blaster does that not mean I have a active JTAG connection? or there is something else?
- sstrell4 years ago
Hmm. Double-check that you've instantiated the ISSP IP correctly and that the nets you are connecting to have not been optimized away for some reason. Check the Compilation report too to see that the on-chip debugging tool has been included in the compiled design. Check that IP that includes the name "sld" (system level debug) has been added to your project hierarchy. This is the JTAG hub that allows a JTAG connection into the device to access on-chip debugging tools.
If it still doesn't work, MAX V may not be supported, but I don't see why it would let you add the IP to a MAX V design if it wasn't supported.
