sidd
4 years agoISSP in Quartus
I am using Quartus lite V20.1 with max V CPLD. Can ISSP be used with this?
Does it require a license version?
If it works then facing following issue with ISSP:
I tried with Quartus lite V 20....
sstrell
4 years agoIf Quartus lets you add the ISSP IP and compile your design in Lite, then it is supported.
Are you programming the device in the .spf file or using the Quartus Programmer? Make sure in the .spf file you have selected the programming cable (USB blaster) and the device.
You can also try Signal Tap.
