13 years agoThanks for the hint rbugalho. In fact, I did just that earlier in the design process. But that didn't work. In my HAL entity I have this:
OTG_OE_n <= usb_read_n;
OTG_WE_n <= usb_write_n;
OTG_D <= usb_d_in when (usb_write_n = '0' and usb_read_n = '1') else (others => 'Z');
usb_d_out <= OTG_D;
usb_read_n and usb_read_n as internal signals, so I don't have to declare OTG_OE_n and OTG_WE_n as buffers (at my working group they say this is bad design practice) to get the tristate working. When I set OTG_WE_n and OTG_OE_n as the targets, TimeQuest says I have unconstrained Clocks: --- Quote Start --- Node: ISP1761Control:ISP1761Control_INST|ISP1761HAL:isp_hal|usb_write_n was determined to be a clock but was found without an associated clock assignment. Node: ISP1761Control:ISP1761Control_INST|ISP1761HAL:isp_hal|usb_read_n was determined to be a clock but was found without an associated clock assignment. No paths exist between clock target "OTG_WE_n" of clock "OTG_WE_n_CLK" and its clock source. Assuming zero source clock latency. No paths exist between clock target "OTG_OE_n" of clock "OTG_OE_n_CLK" and its clock source. Assuming zero source clock latency. --- Quote End --- When I hit "Report Unconstrained Paths" usb_write_n and usb_read_n are listed as unconstrained Base Clocks, since they are feeding OTG_OE_n and OTG_WE_n. I assume the "Assuming zero source clock latency" is not so good for analysing the timing :)
