Is there any recommended way to generate "ASMI parallel ip" readable configuration data file?
- 5 years ago
You can create your own interface to communicate with the ASMI block. For the binary file, you can create the rpd (raw programming file) file using "Convert Programming File" feature in Quartus.
You may refer to https://www.intel.com/content/dam/altera-www/global/en_US/uploads/b/b2/Tutorial_Write_Raw_Programming_Data_(.rpd)_into_flash_devices.pdf which is the example design which utilize JTAG to Avalon Master interface to write to the flash.
- RobertLiang5 years ago
Thank you very much!
