gyuunyuu
Contributor
5 years agoIs there a dedicated way to read/write file into design using system console?
System console contains commands to read/write specific address locations inside the design. This is good to read/write small amount of data. However, what if the user wants to write several MB of da...
SyafieqS
5 years agoHi Hassan,
Yes, system console is not designed for what you intended and signaltap is probably the best way to monitor your signal for faster operation.
- gyuunyuu5 years ago
Contributor
signaltap can monitor signals, here I am referring to writing a few MB of data into FPGA or reading it back. How is signaltap supposed to help in this?
