gyuunyuu
Contributor
5 years agoIs there a dedicated way to read/write file into design using system console?
System console contains commands to read/write specific address locations inside the design. This is good to read/write small amount of data. However, what if the user wants to write several MB of da...
sstrell
5 years agoSystem Console isn't really designed for what you're proposing. It's meant for reading and writing particular address locations and monitoring locations for periodic reading. Remember, in most cases you're using this over JTAG at most 24 MHz.
You can monitor things faster using tools like Signal Tap or Signal Probe. For writing, remember you can initialize a RAM and have your design access that ROM during operation.
gyuunyuu
Contributor
5 years agoI had assumed that the system console could stream data into the FPGA and this will solve the problem. The data is going to be a few MB at most, the FPGA might have to store it in an external RAM at the end.
