Branden_Allen
7 years agoIs the systemverilog "case inside" statement for definitions of a range of conditions within a case block available for synthesis and, if not, when will this be implemented?
Description Using the "inside" keyword with a "case" block to enable the definition of ranges for a desired output value in systemverilog code (cf. attached example) synthesis fails on an apparent s...
Vicky1
7 years agoHi,
'case inside' is not supported in Quartus, only 'unique/priority support available on case statements
Quartus text editor recognizes it as a key word (it shows up in blue color).
refer the below attachment,
Best Regards
Vikas Jathar
