DGARC21
7 years agoIs the IrDA UART setting the same for the TX and RX signals?
I'm trying to use IrDA UART in Nios II to send and receive signals to an FTDI 232. I am using the UART setting: 9600bps, none parity, Data Bit 8, stop bit 1. I can perfectly read the information ...
DGARC21
7 years agoThe input and output signals of the IrDA UART core are different, input signal follows the UART protocol but output signal follows another protocol, I believe the difference is necessary to transmit the information through a photoemitter, allowing it to be received by a phototransistor.
For two-way UART communication, the most correct is to use RS232 UART core. My problem has been solved.
Thank you for your interest.
