Altera_ForumHonored Contributor13 years agoIs that possible to pause a system? In a design, I try to use a FIFO to build a handshake interface between two clock domains to transfer data. However, read rate can not grantee that its rate is higher than write. Therefore, in some c...Show More
Altera_ForumHonored Contributor13 years agothen you are on the right track ;). glad my suggestions help.
Recent DiscussionsCompile option not saved (reversed to default)quartus pro 25.3 bug?SSLC Login Issue – "You need to enroll" loop after OTP verificationflexlm errorQuesta Sim on Windows - linking to external LIBSolved
