10 years agoIs Quartus Prime 16.0 available for 32 bit Windows?
I recently downloaded "QuartusLiteSetup-16.0.0.211-windows.exe" from Altera Download Center for my laptop running Winodws 7 - 32 bit. When I proceeded to install this, Quartus installer gave me a question. It said in a dialog box, "The Altera Software you are installing is 64-bit software and will not work on the 32-bit platform on which it is being installed. Do you want to continue to install the software?". Nevertheless I installed it, and as said by the installer, it did not run.
I am unable to find Quartus Prime 16.0 32-bit for Windows. Where can I get it?2 Replies
starting with Quartus 14.0, only 64 bit systems are supported (see footnote 1 here (https://www.altera.com/support/support-resources/download/os-support.html)). Best regards, GooGooCluster - Altera_Forum
Ok. Thanks GooGooCluster
--- Quote Start --- Hi, starting with Quartus 14.0, only 64 bit systems are supported (see footnote 1 here (https://www.altera.com/support/support-resources/download/os-support.html)). Best regards, GooGooCluster --- Quote End ---
