JTixi
7 years agoIs it possible to force all I/O HighZ before programming (CPLD Max_V)
On our circuit board, the TDO line as been linked through another I/O pin which is not used in the project (BGA 100 package). The first programmation was good. However the unused I/O are linked to g...
YuanLi_S_Intel
7 years agoHi Jean,
By right the I/O pin are tri-stated with weak pull-up before configuration, i dont see any problem here. If you would like to program the device again after it is in user mode, you may change the state of the unused pin. To do so, go to Quartus -> Device -> Unused Pin -> Input pin as tri-stated with weak pull up.
YL
