AWels
7 years agoIs it possible to create an IBIS model from information in the pin planner with no other VHDL or Verilog in the design?
I am a PCB-level hardware designer trying to get an early insight into the SI performance of the PCB. I have found that error messages such as 15716 occur, or the pin planner crashes when I try to ...
YuanLi_S_Intel
7 years agoHi Adrian,
Yes, you can do so. However, you need to have the information in pin planner such as the pin used, I/O standard and other relavant I/O setting.
YL
