ScottHu2021
4 years agoIs it necessary to add timing constraint for the nios_custom_instr_floating_point_2?
In our FPGA project, we instantiate a NIOS and connect a custom_instr_floating_point block to the NIOS for floating calculation speed-up.
But after adding the floating point calculation bloc...
SyafieqS
4 years agoScott,
There is example how to run the constraint set multicycle path via link below. Could be useful if you are running the source and destination clock at different speed.
