8 years agoIs export/import design partitioning supported when HPS is in the partition?
Tools: Quartus Prime Standard v17.1 Target device: Arria10 SoC Is it possible to import a design partition which contains an hard processing system (HPS)? For example: - ProjectA co...
8 years ago --- Quote Start --- Since you have to use Qsys (Platform Designer) anyway to build a system with the HPS, why not just reuse the .qsys file in Project B? Doing this seems needlessly complicated. --- Quote End --- You're absolutely correct and I wish it were that simple for our case. The background story is that we have a FPGA build framework which relies upon the incremental complication and import/export of design partition of the Standard tools suite. Within this framework, the HPS is located in a submodule (partition) rather than in the top-level module. While we've been using the Standard tools (incr comp, import/export) in this manner for years, we've never had the need to include an HPS, until now. I'm reading through the vast amount of Intel docs, but I have not been able to determine if HPS are supported in a partition. Are you aware of any restrictions or recommend a doc that might discuss this subject?
