Michael19's avatar
Michael19
4 years ago
Iquartus prime pro: IP Catalog is empty
Hello out there,
i am using a freshly installed Quartus Prime Pro 22.1 system, running on a CentOS linux machine.
As the license is not yet available, i activated the "Grace Period".
Then i used the New Project Wizard to create a empty project which selects as family Stratix10
As device i selected Stratix10 DX which corresponds to the board we will use .
The strange thing is that the IP Catalog is empty.
Btw. in PlatformDesigner the IPs are shown and can be used, but there's another issue with this tool.
I searched for the IPs in the file system and added the path to the installation manually under option "IP Catalog Search Locations" / global IP search directory like below, but this did not solve the problem.
/cae/tools/altera/quartus-pro_22.1.0/ip
Is there another place where the path to the default IP library is stored ?
Setting the option above writes a key "USER_IP_SEARCH_PATH = ... in quartus2.ini .
Editing or extending this by hand did not help.
I tried several variants, f.e.
/cae/tools/altera/quartus-pro_22.1.0/ip/**/* <- this gets written into the file when using the setup option above
/cae/tools/altera/quartus-pro_22.1.0/ip/altera/*
Thanks to all
  • Since there are no feedback for this thread, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Richard Tan
  • sstrell's avatar
    sstrell
    I think for this and your other post, you might have a bad installation. I'd uninstall, re-download and re-install.
  • You should not need to do all that and the IP catalog should show all the IP normally.
    I recommend that you uninstall the whole Quartus as mentioned by Sstrell and reinstall again.
    Richard Tan
    • Michael19's avatar
      Michael19
      complete reinstall was done yesterday - IP catalog is visible now
