18 years agoI'm using SGDMA (Scatter-Gather DMA) component to do that, works fine.
The only problem I have with SGDMA is that it forces you to use 64-bit registers for all the other native addressing peripherals in your system because Altera has been lazy and has not put in an option to reduce the descriptor memory data width.
