EIbra
7 years agoIP Upgrade fails
Quartus 18.1 project from Quartus 16 with altsyncram 1) Open project, upgrading with GUI - MegaWizard hangs. one IP is not upgradable - altsyncram 2) quartus_sh --ip_upgrade -mode all test_hea...
AnandRaj_S_Intel
7 years agoHi,
I have tested using Quartus 13.0 and generated altsyncram and updated IP to Quartus 17.1 & Quartus 18.1 with out any error.
Can you again by deleting db and incremental_db folders with GUI or command line.
- Select the IP core in the Upgrade IP Components dialog box.
- Click Upgrade in Editor. The parameter editor appears.
- Click Finish or Generate to regenerate the IP variation and complete the upgrade. The version number updates when complete.
or
- Use quartus_sh -ip_upgrade -variation_files <file.vhd/.v> <projectname>
If possible attach by archive project?
Reference-> session 1.5 https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_intro_to_megafunctions.pdf
Anand
- EIbra7 years ago
thank you,
this helps
