VGopa7
4 years ago"ip-deploy" gives error in Intel Quartus Pro 20.3
The command "ip-deploy" errors out in Intel Quartus Pro version 20.3. The same command works in other verion of Intel Quartus Pro 20.2 or 21.3
Below is the error log using Intel Quartus Pro 20.3: ...
RichardT_altera
4 years agoHi
I don't use much scripting for Platform designer. Do you mind to share the script file to duplicate this error?
Since you mentioned that Pro 21.3 works for you, I recommend to use the Quartus Pro 21.3 as a workaround.
Richard Tan
