IP core scripting or regeneration from QIP
- 5 years ago
Ya, you can also easily create a script that makes all the assignments for an existing project, and then use the script at any time to restore your project settings to a known state.
From the Project menu, click Generate Tcl File for Project to automatically generate a .tcl file with all of your assignments. You can source this file to recreate your project, and you can edit the file to add other commands, such as compiling the design.
To answer back if there's is a way to get the generation script for the IP Core after use the megawizard to create:
I don't think there is a way to do that, you might need to manually write the script. It's best to provide the .qip or .ip file directly to the user.If you want to generate an IP using a script or the command line interface, you may checkout an example KDB below:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd12182013_862.html
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
