IP core scripting or regeneration from QIP
- 5 years ago
Ya, you can also easily create a script that makes all the assignments for an existing project, and then use the script at any time to restore your project settings to a known state.
From the Project menu, click Generate Tcl File for Project to automatically generate a .tcl file with all of your assignments. You can source this file to recreate your project, and you can edit the file to add other commands, such as compiling the design.
To answer back if there's is a way to get the generation script for the IP Core after use the megawizard to create:
I don't think there is a way to do that, you might need to manually write the script. It's best to provide the .qip or .ip file directly to the user.If you want to generate an IP using a script or the command line interface, you may checkout an example KDB below:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd12182013_862.html
Do you meant to migrate the IP to another project? If so, I believe .qip or .qsys or .ip file should be good enough.
To modify one of your existing IP core variations, perform one of the following:
Option 1: Click File > Open and select the top-level HDL(.v, or .vhd) IP variation file to launch the parameter editor and modify the IP variation. Regenerate the IP variation to implement your changes.
Option 2: Click View > Utility Windows > Project Navigator > IP Components and double-click the IP variation to launch the parameter editor and modify the IP variation. Regenerate the IP variation to implement your changes.
I recommend option 2 as the way to make changes to the IP.
Option 1 is the option used when you lose the .qip file. Any changes made in the .v file will be lose upon running the .qip in megawizard (currently called IP Catalog).
To know more about Intel® FPGA IP Cores, you may checkout the document below:
So in your script to build a new project using that IP you would just include the file location of the .QIP file and that should be all you need?
- RichardT_altera5 years ago
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd12182013_862.html- TMayd5 years ago
Okay, thank you for your responses!
