VCham's avatar
VCham
8 years ago
IP Component files generated in wrong directory
I used the Altera PLL IP to generate a PLL for my project but it was generated in the wrong directory. I tried moving the files but Quartus II was then unable to find the IP Component. Is there a proper way to move these generated files within my project folders?
  • I figured out my issue.
    What I meant by "wrong" was that it wasn't generated in the desired folder given our folder structure convention, and simply moving the files didn't update the pointers. I figured out that updating the paths found in the .qsf file solves the issue.
  • AndyN's avatar
    AndyN
    What do you mean by the "wrong" folder? Where is it generating with reference to the .ip file?
  • VCham's avatar
    VCham
