11 years agoI/O pins located in a block
Hello, I have a very simple problem : I would like to map some of the I/O pins of the FPGA, which are connected to a wide external bus (hsma_d[75..0]) on a commercial board, to an internal b...
11 years agoI believe PietervanderStar is right. In some cases, I would create a design and allow the Quartus II Fitter to find the optimal placement for certain pins. Without having the pin defined at the top level, Fitter will ignore them or probably trigger error/warning that a pin should be connected.
