11 years agoI/O pins located in a block
Hello, I have a very simple problem : I would like to map some of the I/O pins of the FPGA, which are connected to a wide external bus (hsma_d[75..0]) on a commercial board, to an internal b...
11 years agoWell there is at least one reason I can think of why it is not implemented. How does the compiler know that your clock or reset port in a component shouldn't be mapped to a pin? Changing those names is not always an option as you frequently use off-the-shelf code.
