11 years agoI/O pins located in a block
Hello, I have a very simple problem : I would like to map some of the I/O pins of the FPGA, which are connected to a wide external bus (hsma_d[75..0]) on a commercial board, to an internal b...
11 years ago --- Quote Start --- I don't think this can be done. As far as I know all FPGA tools operate on the principle that everything at the top level goes to a pin, and everything that isn't doesn't go to a pin. --- Quote End --- thank for your reply. this is also the answer I received from colleagues. let's hope that this feature will be implemented one day... best regards
