invalid jtag configuration on signaltap
If programming was successful in the Quartus Programmer (instead of doing the programming from the JTAG Configuration section of the Signal Tap window), Signal Tap sometimes will still have this message. Just try clicking the start analysis button as usual to see if it still works. If it doesn't, you may have made a change in your Signal Tap file that requires a recompilation, so the Signal Tap file doesn't match the Signal Tap configuration programmed into the device.
- RichardT_altera5 years ago
Does the suggestion from sstrell works for you? Do you need further help on this case?
We do not receive any response from you to the previous reply that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
