Duko
4 years agoInternal Error: Sub-system: VPR20KMAIN altera_arch_route_lookahead
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_route_lookahead.c, Line: 4315
During the routing the Internal Error above shows up. This is cons...
RichardT_altera
4 years agoHi @Duko
It seems that this internal error is not found in our database. So there is no known workaround currently for this internal error (IE).
Since this is old version of Quartus, we recommend to upgrade the project to the latest Quartus version as there is a lot of fix being done.
If the design is too large, it will not fit in the device selected.
Richard Tan
- RichardT_altera4 years ago
Hi @Duko
Do you still see the IE in the latest Quartus version?
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- Duko4 years ago
Hi Richard,
Thanks for poling on the progress.
I still need to complete the transition/porting IPs to a newer version.
So work in progress.Best Regards
