8 years agoInterfaces and Synthesis
I am trying to use interfaces for use in abstraction and simplification of port connections. Something structs cannot do very well because they cannot carry information about direction. However, I ca...
8 years agoLooking back on the sources I have used on this topic I misunderstood and botched the syntax. It should have looked like this.
interface EMIF_Bus (
input wire EMIF_addr,
output logic EMIF_data,
input wire EMIF_readEnable
endinterface
module interface_top (
input clk,
input reset,
input addr,
output data,
input readEnable
EMIF_Bus module_io (
.EMIF_addr (addr),
.EMIF_data (data),
.EMIF_readEnable (readEnable)
interface_sv SYSTEMVERILOG_DUT
.clk (clk),
.reset (reset),
.module_io (module_io)
The above interface definition allows for external variables and nets to be connected to the interface. However, it requires a declaration and connection of external variables/nets to the interface. From there any module sharing this declared interface will have access to these signals. So, this solves the issue.
