SOkte
7 years agoInterface Planner, why no assignments after Initialization of Interface Planner
In the Interface planner I see a report in the Reports Tab In the Interface planner I do not see assignments in the Assignments Tab, but I do have assignments that can be seen from Assignment Edit...
sstrell
7 years agoWhat's the "125" filter you have enabled on the Assignments tab?
I'm not sure if I/O standard assignments would appear in the Assignments tab of Interface Planner, only location assignments. Try adding a single location assignment in the Pin Planner, then go back into Interface Planner. See if the location assignment you created appears.
#iwork4intel
