10 years agoInteracting with System-console from Python
I'm looking to make some integration with system console and Python 3.5 for a test that I'm running. What I would like to do is write some python that will use something like "subprocess" to bind to...
myoga1
7 years agoAt this point, you should have a working Python 3 interpreter at hand. If you need help getting Python set up correctly, please refer to the previous section in this tutorial series.
Here’s what you’ll learn in this tutorial: Now that you have a working Python setup, you’ll see how to actually execute Python code and run Python programs. By the end of this article, you’ll know how to:
- Use Python interactively by typing code directly into the interpreter
- Execute code contained in a script file from the command line
- Work within a Python Integrated Development Environment (IDE)
