9 years agointelFPGA_lite crashes at launch (Inconsistency detected by ld.so: dl-close.c: 811)
OS: Ubuntu Xenial 16.04 Installation went through smoothly. Sadly quartus just crashes at startup. What is the best way to file a bug? $ ~/intelFPGA_lite/16.1/quartus/bin/quartus Incon...
9 years agoHi,
I have Quartus 17.0.1 running on my Ubuntu16.04 64 bits LTS. After the fresh instalation you just need to fix the following 2 errors: Fix error 1: intelFPGA/17.0/quartus/linux64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/lib/x86_64-linux-gnu/libproxy.so.1) Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so $ cd ~/intelFPGA/17.0/quartus/linux64 $ mv libstdc++.so.6 libstdc++.so.6.bak $ ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 libstdc++.so.6 Fix error 2: Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed! $ mv libccl_curl_drl.so libccl_curl_drl.so.bak
