Intel Questasim is very slow, e.g. cd ..
- 3 years ago
Finally I found the reason for the slow behaviour.
If I remove the intel/altera specific libraries from the default modelsim.ini, the questasim is fast again.
Yet I didn't check, if there is a specific library or if the amount of libraries makes questasim slow. Since my code is platform independent, I removed the altera libraries from the modelsim.ini.
Works for me and hopefully helps other FPGA developers to find a solution for this issue.
Thanks for trying to help.
Hard to tell what's going on. What's your installation path and is it different from the "fast" machine? Have you tried uninstalling and reinstalling? Internal or external drive installation? Other apps running? Same behavior right after a reboot? Task Manager showing anything eating cycles?
