areebTAG
4 years agoIntel Quartus Prime(Lite Edition) unable to compile code
I am trying to compile& simulate VHDL code for a multibit adder along with its testbench. The code is tested in Questasim and it works fine however Questasim is giving errors which I can't quit...
areebTAG
4 years agoso what about if you wanted to simulate you code first using Questasim? Intel Quartus does the option for running a rtl simulation, correct?
sstrell
4 years agoQuartus can generate script files so you can simulate in Questasim. It doesn't do a simulation compilation.
