6 years agoIntel PCIE 512bit Controller
I am using Intel P tile avalon MM PCIe Express and Intel PCIE 512 bit controller
Warning(16735): Verilog HDL warning at intel_pcie_dma_hwtcl.sv(329): actual bit length 174 differs from forma...
SengKok_L_Intel
6 years agoHi,
I have generated an example design by using v20.3, and also observed quite a number of "lost fan out" from the IP or DMA controller. Since this happens within the internal IP logic, and those logic might be reserved or not actually using, therefore, there is no way for us to eliminate it. You can just safety ignore it as we don't expect it will impact the IP hardware functionality.
Regards -SK
