RLedu
5 years agoIntel Modelsim simulation of IP without its license
I try to run a simulation in modelsim with a qsys design called "soc_system" including, in my case, the JESD204B IP, which requires a licence. I know I will need license to compile in the end m...
RLedu
5 years agoHello Wani,
Thanks for the answer !
So I understood well that it is possible to run Modelsim simulations with evaluation mode of licensed IPs.
However I believe I already got the evaluation or "free" version of the JESD204 IP because I can succesfully compile a design and reach the "time limited" version of .sof file. While to use it for Modelsim, I cannot at all ! Do you have any suggestion ?
I use Quartus Prime Standard Edition 18.0 and ModelSim Starter edition 10.5b.
Thanks again
Zawani_M_Intel
5 years agoDo you get any error or it is not working at all?
If you get the error, can you copy it here?
Wani
