Instantiation of DDR3 SDRAM Controller with UniPHY intel FPGA IP
Hi Scott,
Every PLL can cover some area of the I/O interfaces.
I think the DDR3 interface can be support at the right side of the Cyclone V device.
So that you need to use the PLL at that area.
But the Quartus can already set for you where by you can see which PLL has been used in the Quartus Compilation Report.
Usually the clock pin is placed in the Address and Command I/O bank.
The clock should be from the Oscillator as you mentioned.
May I see the timing report for DDR?
Adzim
Hi Adzim,
In our design, the clock input pin is not placed in the same I/O bank as DDR interface's, and it is used as the PLL reference clock of the DDR3 controller through a clock control block.
- With the PLL reference clock frequency setting of 100M, the DDR3 can work, and the DDR timing report is as following:
report_ddr -panel_name "DDR" -multi_corner
Initializing DDR database for CORE ddrc_p0
Finding port-to-pin mapping for CORE: ddrc_p0 INSTANCE: ddrc_u|ddrc_inst
PLL clock ddrc_u|ddrc_inst|pll0|pll1~PLL_OUTPUT_COUNTER|divclk not driven by a dedicated clock pin or neighboring PLL source. To ensure minimum jitter on memory interface clock outputs, the PLL clock source should be a dedicated PLL input clock pin or an output of the neighboring PLL. Timing analyses may not be valid.
Report Timing: Found 10 setup paths (0 violated). Worst case slack is 0.048
Report Timing: Found 10 hold paths (0 violated). Worst case slack is 0.303
Report Timing: Found 10 recovery paths (0 violated). Worst case slack is 11.589
Report Timing: Found 10 removal paths (0 violated). Worst case slack is 0.965
Core: ddrc_p0 - Instance: ddrc_u|ddrc_inst
setup hold
Address Command (Slow 1100mV 85C Model) | -0.186 1.878
Bus Turnaround Time (Slow 1100mV 85C Model) | 4.322 --
Core (Slow 1100mV 85C Model) | 0.048 0.303
Core Recovery/Removal (Slow 1100mV 85C Model) | 11.589 0.965
DQS vs CK (Slow 1100mV 85C Model) | 0.44 0.552
Postamble (Slow 1100mV 85C Model) | 0.817 0.817
Read Capture (Slow 1100mV 85C Model) | 0.307 0.26
Write (Slow 1100mV 85C Model) | 0.633 0.639
DDR Timing requirements not met
- With the PLL reference clock frequency setting of 25M, the DDR3 writing/reading failed, and the DDR timing report is as following:
Report Timing: Found 10 setup paths (0 violated). Worst case slack is 1.949
Report Timing: Found 10 recovery paths (0 violated). Worst case slack is 11.631
Report Timing: Found 10 removal paths (0 violated). Worst case slack is 0.838
setup hold
Address Command (Slow 1100mV 85C Model) | 0.955 0.948
Core (Slow 1100mV 85C Model) | 1.949 0.303
Core Recovery/Removal (Slow 1100mV 85C Model) | 11.631 0.838
Scott
