17 years agoThankyou for that I think I understand but Im still not quite sure, I have a ram file for a dual port RAM which has been modified and is not produceable directly by the wizard. Until I learn more about this I would like to generate two of these. Can I create an instatiate code block which uses this file to make several 512 byte dual port RAM blocks in the FPGA? If not do I need to modify the originals and save again as another file name?
Thankyou ever dso much for a swift reply and help its appreciated. Robin
