12 years agoInstalling Quartus Programmer on Linux
Hola, I'm trying to install the web edition of Quartus 11.0.SP1 on Ubuntu 14.04. I have re-linked sh to bash, and have install tcsh. When I run the installer, I get this error: keil...
12 years ago --- Quote Start --- Hola, I'm trying to install the web edition of Quartus 11.0.SP1 on Ubuntu 14.04. --- Quote End --- If anyone else is having trouble with this, these steps helped me set up Quartus 11.1 on Ubuntu 14.04: chmod 700 11.1_173_quartus_linux.sh bash 11.1_173_quartus_linux.sh cd 11.1_173_quartus_linux mv altera_installer/bin/libpng12.so.0 ../ bash ./setup Inspiration from here: https://forums.gentoo.org/viewtopic-t-571770-start-0.html on the libpng issue. Cheers.
- OBlan27 years ago
This also works on Ubuntu 16.04 LTS for Quartus ii and ModelSim installers.
The reason to move the the libpng12.so.0 out of the bin folder is that it does not work, so, you are forcing the installer to look in any other location.
The library is available to be installed from the Ubuntu repo for the i386 and x86_64 architectures.
