12 years agoInstalling Quartus Programmer on Linux
Hola, I'm trying to install the web edition of Quartus 11.0.SP1 on Ubuntu 14.04. I have re-linked sh to bash, and have install tcsh. When I run the installer, I get this error: keil...
12 years ago --- Quote Start --- Hello, I have been having the same problem on Ubuntu14. I must use quartus version <= 11.1 since I need support for my device Max 7000 family...it is very annoying that this libpng12.so.0 (that is shipped with the installer) keeps preventing installing the program...even if I change the LD_LIBRARY_PATH to first have the /usr/lib (or whatever) in the list the installer still keeps picking up the libpng12.so.0 sitting in the installer's directory. Also, if I replace it with a symbolic link to point to the system libpng12.so.0 (sitting in /usr/lib/) then the installer says that I don't have a valid installation source... Actually a similar problem occurs when I try to start a browser in the Help menu, then I get an error saying something is wrong with the shipped libstdc++6.so.0, but at least replacing that with a symbolic link pointing to the system one under /usr/lib solved the issue.. Balint --- Quote End --- Ok, I've actually got it working. I wont go into too much detail, but there was one fundamental I didn't understand, and one underlying OS design I didn't understand. 1. QProgrammer doesn't know about my chip. I had to tell it about my chip by launching the GUI, choosing my blaster, scanning the blaster, choosing the unknown chip, then richt click, "Change Device", Select the random chars in right window, "Edit" and entered the details. I am lucky in that the cdf instructions for that particular chip were ignore - YMMV. 2. I can't quite explain, but it goes something like this: Every time qprogrammer threw a hissy fit, I noted which file was missing (it happened about 10 times before I got it to launch). I would then "sudo apt-file -s i386 search <file>" to find which package contained that file, and then "sudo apt-get install <package>:i386". The "colon three-eight-six" was important - it installed the correct libs. For furhter research, these pages are how I cobbled together this solution: http://www.alteraforum.com/forum/showthread.php?t=35885 http://askubuntu.com/questions/52617/what-is-usr-lib-i386-linux-gnu-for http://unix.stackexchange.com/questions/119798/mint-correct-way-to-install-lib-i386-linux-gnu-libgmp-so-3 Final note: despite all attempts otherwise, was never able to get QP 64bit working (using the --64bit flag)
