11 years agoInstalling Quartus II on Ubuntu 14.0 LTS and USB Blaster problem
Hi everybody, I have installed Quartus II 15.0 (tried 13.1 as well) on Ubuntu 14 LTS and had no problem with the installation at all. However, the USB Blaster and jtag toolchain is not recogniz...
11 years agoHi, are you able to access USBBlaster with root privilege?
is present altera blaster if you type lsusb on terminal? if yes to both question you can setup USB setting port permission, see here: http://rocketboards.org/foswiki/view/documentation/usingusbblasterunderlinux or from Altera instruction page here: https://www.altera.com/support/support-resources/download/drivers/dri-index.html I am using Linux Mint 17.2 that is a derivative from Ubuntu, it work fine and I am able to compile and load my VHDL to DE1SOC, MAX10, MAX V MAX II. Best regards Robert
