10 years agoInstalling Quartus II 15.0 over 15.1
I was working my way through the Deca Kit labs posted on the wiki, and ran into some troubles with Lab 8. I was recommended to rollback from Quartus II 15.1 to 15.0 (because the labs are know to work with 15.0, and the IP changes to 15.1 seem to cause problems). So, my question is, can I just install 15.0 next to 15.1, or do I need to uninstall 15.1 to safely install 15.0? Thank you, ngohara3 Replies
You can install 15.0 without uninstalling 15.1. Make sure it isn't using the same directory as 15.0. For example C:\altera\15.0 and C:\altera_lite\15.1 will work fine.
Its quite common to have several versions of quartus installed on the same system for compatibility issues.
--- Quote Start --- Its quite common to have several versions of quartus installed on the same system for compatibility issues. --- Quote End --- Thank you both for the help
